Posted: Wed Jan 09, 2013 6:38 am |
Best place to get the bulbs for the center display and the air-con display.
Is a 2004 if it makes any difference.
Posted: Wed Jan 09, 2013 6:40 am |
eBay?
Posted: Wed Jan 09, 2013 9:50 am |
it makes no diff. if it's 2004 or 2008 :D,buy the tungsram brand,it's the best
Posted: Wed Jan 09, 2013 9:53 am |
If you mean the MFD, then they are 509t, readily available at any accessory shop. The AC display I think uses SMD which will need soldering in. Not as easy available and more work to change.
Posted: Wed Jan 09, 2013 11:51 am |
Nope, on the ac display the bulbs can be removed by twisting. Dont think they are the same as the MFD. Thanks for the 508T ordered them already.
Posted: Sun Jan 13, 2013 9:10 am |
As you will see there i ordered/miss read it and got 508t so they are very dim. Just ordered the 509T. Take two.
