Posted: Sun Jan 20, 2013 2:23 pm |
I fitted a new stereo and to make the stereo come on with the ignition I cut the ignition wire and linked it into the power. Big mistake I think the wiring diagram I had was probably wrong as although it worked as I intended I blew my ESP.
I have checked the fuses and they all seem fine however I don't have the manual to see which fuse it what. What do you think I have done as it just says not functioning all the time ![Sad Sad](images/smiles/icon_sad.gif)
Car is a gti 180 btw
| | ![](images/spacer.gif) |
Posted: Sun Jan 20, 2013 2:27 pm |
Look in the forum FAQ as the fuse lists are posted in there.
Posted: Sun Jan 20, 2013 2:29 pm |
MrBSI wrote: |
Look in the forum FAQ as the fuse lists are posted in there. |
Thanks I've just looked and when checking the fuses under the bonnet i've already looked at the one which is linked to esp fse 3 and its fine have also swapped it with another and still the same.
Posted: Sun Jan 20, 2013 2:35 pm |
Is that under bonnet or in car?
Posted: Sun Jan 20, 2013 2:36 pm |
Have you disconnected the radio and put everything back as original?
Posted: Sun Jan 20, 2013 2:39 pm |
Steve206 wrote: |
Have you disconnected the radio and put everything back as original? |
Its under the bonnet and yeah i've put all the wiring back as it was. Also just been and rechecked with a new fuse and nothing ![Sad Sad](images/smiles/icon_sad.gif)
Posted: Sun Jan 20, 2013 3:22 pm |
Do your getting the warning on screen about ASR/ESP DEACTIVATED. any abs lights? Might possibly need a code read?
Posted: Sun Jan 20, 2013 3:46 pm |
Steve206 wrote: |
Do your getting the warning on screen about ASR/ESP DEACTIVATED. any abs lights? Might possibly need a code read? |
Thanks for the reply I've just been out in the snow to look again and I've fixed it Fuse no 6 had originally blown which I replaced but as it was still wired wrong i'm guessing its blown it again as was blown. The wiring has been fixed recently so put in a new fuse and its fine now ![Smile Smile](images/smiles/icon_smile.gif)
