Posted: Fri Aug 10, 2012 5:39 am |
how do I remove the outer black plastic door trim [body guard / side mouldings] please?
many thanks.
| Peugeot 206 HDi (1.4cc) 'eco' - 2005 | |
Posted: Fri Aug 10, 2012 5:56 am |
Trade Rating: +36
Open the door. Grab it from where it folds in then push from the other end.
Posted: Fri Aug 10, 2012 6:02 am |
Just pull it off but watch out you will guarantee to break the plastic lug clips that hold it on so best to go buy some before hand they are like 3p from peugeot!
Posted: Fri Aug 10, 2012 6:04 am |
Trade Rating: +36
You will break them if you pull it off. Slide it out slowly and all clips shoud be intact. Your a bloody cowboy Iain
Posted: Fri Aug 10, 2012 6:06 am |
-Dave- wrote: |
You will break them if you pull it off. Slide it out slowly and all clips shoud be intact. Your a bloody cowboy Iain  |
woohoo! that would explain it!
Posted: Fri Aug 10, 2012 6:09 am |
-Dave- wrote: |
Open the door. Grab it from where it folds in then push from the other end. |
Push from the 'pointy end' BACKWARDS [toward the rear of vehicle]?
Is there a clip or fastener at the 'folded end' [door opening end] that needs to be pulled forward, away from the door a little bit first?
many thanks!
Posted: Fri Aug 10, 2012 11:58 am |
Trade Rating: +36
PUGPAUL wrote: |
-Dave- wrote: |
Yes
No, Just get your nail's behind it and ease it forward a little bit then push from the other end.
many thanks! |
Posted: Sat Aug 11, 2012 4:44 pm |
-Dave- wrote: |
PUGPAUL wrote: |
-Dave- wrote: |
Yes
many thanks! |
In the end it actually pushed forwards, toward the front of the car to release the clips [at back].
Posted: Fri Jan 18, 2013 11:00 am |
Posted: Fri Jan 18, 2013 11:29 am |
Was just about to ask same thing lol cheers
