Latest: Beduff1977
Overall: 17134
Online Now [488]:
Visitors: 487
Today: 148737
Total: 108964483
Forums › The Car › 206 Talk › Where can I get this connector
P6RAF
PostPosted: Wed Jan 30, 2013 8:41 am Up
Title says it all really.
I'm after two male connectors like the one below.
The pair look like this..
2004 206 HDi GTi, Obsidian Black.
VW Polo 1.3 GL - 205 GTI 1.6 - 306 D-Turbo - First 205 GTI 1.9 track car - Second 205 GTI 1.9 Track car - 106 XLD - Impreza WRX - 406 V6 - 206 HDi GTi
iainlovatt
PostPosted: Wed Jan 30, 2013 8:56 am Up
Pm'd
(My Garage)
PostPosted: Wed Jan 30, 2013 10:55 am Up
I'm after two female connectors like the one below.
That's a male connector.
P6RAF
PostPosted: Wed Jan 30, 2013 11:13 am Up
PostPosted: Wed Jan 30, 2013 12:46 pm Up
That's the female. The male plug inserts into the female regardless of what the pins looks like.
P6RAF
PostPosted: Wed Jan 30, 2013 1:06 pm Up
DOH!!! Lets forget about female or male connector. Wall Bang
I just need 2 more
(But I think E5GDM is correct. I too thought it was the casing that identified male or female but I did a quick google and it does seem that the pins matter.)
Either way, it's not that important. But please can someone help me get 2 more.
Does anyone have any old/broken phase 2 lights they don't mind taking them from ?
PostPosted: Wed Jan 30, 2013 2:32 pm Up
You can get the wiring loom plugs and terminals from the Peugeot dealer although you might struggle with the part attached to the lights.
P6RAF
PostPosted: Wed Jan 30, 2013 2:36 pm Up
Interesting Edward. The connector looks like it could detach from the lights as there seems to be a squeeze release tab on it.
I'll contact my main stealer and see if they can help.
Thumb Up
PostPosted: Thu Jan 31, 2013 9:12 am Up
It's the pins that count Very Happy
PostPosted: Thu Jan 31, 2013 11:57 am Up
Have you looked at the connectors section on Servicebox? There is definately something that resembles both parts of the connection.
PostPosted: Thu Jan 31, 2013 12:03 pm Up
are those superseal connector?
PostPosted: Thu Jan 31, 2013 12:20 pm Up
Naah. They are made by some other company beginning with an S I think but work the same way.
