Posted: Sat Jan 26, 2013 4:59 pm |
I have got a peugeot 206 1.1 1998 which the gearbox has gone in would anyone be able to tell me if the gearbox from a 1999 Roland Garros would fit it?
Posted: Sat Jan 26, 2013 5:51 pm |
be ok as long as the rg is also a tu 8v so will have same ma type box
Posted: Sat Jan 26, 2013 6:12 pm |
I imagine the RG will have different ratios because it's a 1.6. Shouldnt be too different though.
Posted: Sun Jan 27, 2013 5:11 am |
Okay cheers will the different gear ratios make much difference?
Posted: Sun Jan 27, 2013 6:45 am |
Doubt it will be significantly different.
Posted: Sun Jan 27, 2013 7:25 am |
Will the drive shafts still fit or will they be different?
Posted: Sun Jan 27, 2013 8:04 am |
If i remember correctly, the 1.6 ones at the diff input are slightly shorter so 1.4/1.1 ones slightly leak
| Team Impossible Possible
Posted: Sun Jan 27, 2013 8:21 am |
could i just swap the 1.1 ones with the 1.6 then?
Posted: Sun Jan 27, 2013 8:40 am |
Yes, the 1.6 will fit your car but if you fitted the 1.1 shafts into the 1.6 gearbox they would not fully sit in/mate and leak ever so slightly.
When you get the box just compared the ends which enter the box and you will see what i mean
Posted: Sun Jan 27, 2013 1:30 pm |
So if I just change the shafts and box everything will be fine?
