Latest: tbafonso
Overall: 17130
Online Now [74]:
Visitors: 73
Today: 20004
Total: 103987931
Forums › The Car › 206 Problems › rear wheel bearing. doesnt match.
Fifer
PostPosted: Thu Jan 31, 2013 1:11 pm Up
I have been looking over the net and cant seem to find the correct rear wheel bearing for my 02 1.4 hdi. My bearing has a tapered style yet most seem to be a straight style. Even euro car parts show a straight one for my reg.
Anybody know where I can get a tapered o
one from
1.4hdi 02
PostPosted: Thu Jan 31, 2013 2:30 pm Up
disc or drum?
Fifer
PostPosted: Thu Jan 31, 2013 3:09 pm Up
Drum
1.4hdi 02
PostPosted: Thu Jan 31, 2013 3:12 pm Up
we only got 1 type of drum bearing.
Fifer
PostPosted: Thu Jan 31, 2013 3:37 pm Up
The type that fell out of my drum looked like this
tjdeinabearing.en.made...0304-.html
All the ones I find for the 206 look like this
item.mobileweb.ebay.co...0846925388
Unless mine should look like the bottom and has seperated? It is definately closer to the top link.
1.4hdi 02
PostPosted: Thu Jan 31, 2013 3:55 pm Up
you are right. even it is taper bearing it can still have a cylinder shape
PostPosted: Fri Feb 01, 2013 4:45 am Up
The shell is still inside the drum. Ideally it needs pressing out, but a hammer and appropriate sized drift can do the job.
There should be a little circlip which holds the bearing in place just below the hub nut and pressure washer. If it's one of the old style, it's a pig to get out.
Fifer
PostPosted: Fri Feb 01, 2013 4:55 am Up
Thanks guys. Ill drop the hub off and have another look. Cheers
1.4hdi 02
