Online Now [304]:
Visitors: 303
Today: 60515
Total: 105954517
Forums › The Car › 206 Problems › fitting 266mm C2 solid discs
andrewkeen
PostPosted: Thu Feb 21, 2013 11:46 am Up
Hi everyone, my girlfrends 206 1.4I 8v failed the mot with worn front discs. Yes they where very bad when I measured them, 11.2mm ops.
Popped up the scrappy and found a C2 with brand spanking new discs and pads. so Took them as they did them for £5 each, and assumed they where the same doing the same engines and chassis. Happy. Hoewever when I got home I found out that the 206 ones are 247mm. So my question is If I go back and get the calipers will they fit the 206? or shall I see if I can get some corrects size dics of keep with the bigger disk if the caplipers fit?
These are the solid disc type.
Andrew
Tolkienfan001
PostPosted: Thu Feb 21, 2013 11:55 am Up
Trade Rating: +13
I have a 1.4 16v and my front discs are 266mm vented. I would guess the calipers should fix you problem.
2005 1.4 16v Sport
Check out my 206 here!
PostPosted: Thu Feb 21, 2013 12:01 pm Up
I removed the 247mm x 13 solid front set up on my TU3 206 & fitted the 266mm x 22 vented set up in its place.
Calipers, discs & pads where a straight swop.
andrewkeen
PostPosted: Thu Feb 21, 2013 12:34 pm Up
Thanks guys just what I wanted to know. Id much rather she be safe so will get the calipers to use the larger disc.
Andrew
