Latest: S2cgm
Overall: 17178
Online Now [257]:
Visitors: 256
Today: 31811
Total: 137461391
Forums › The Car › 206 Problems › fuel pump wont prime
kanye
PostPosted: Tue Feb 26, 2013 4:52 am Up
Hi im New to the forums I have a peugoet 206 1.4 y reg engine in a 1.6 shell I got it like this it petrol I have had it on the drive 4 mouths now the first 1/2 mouth the car could start now the last 2 mouth it won't star I look at the fuel pump it not priming I checked the plug going to the pump it got power going there so i checked the relay that's fine i checked the fuse i t had blown so I put a new one in it started to prime ran fine then it started to dye agian what could it be
Pump is fine
Relay is fine
Could be a fuse
Or shorting out maybe
Any help will be grate as gf is preg need the car thanks
PostPosted: Tue Feb 26, 2013 6:57 am Up
Is it the fuse in the engine bay which is blowing, and when does it start to die? If it starts, but then cuts out, its more than likely a fuse.
kanye
PostPosted: Tue Feb 26, 2013 9:56 am Up
Thank for the reply well don't no what data I was run the car and the 5/10 minutes the engine judder then cut out, that when I thought of the fuel pump but thats ok the fuse under the steering wheel
