Posted: Sun Feb 24, 2013 5:43 am |
Hi,
Sometimes normally in the cold weather, when I try to lock the doors with the key fob, the doors will not lock then lock for a second then both open again.
I then click the key fob until it gives up locking the car then I use the key to lock the car. When I do this the door will still not lock I lock one side only for the other side to the open up.
Also how would I lock the boot? And how would I fix the lock issue?
| | ![](images/spacer.gif) |
Posted: Sun Feb 24, 2013 6:46 am |
Trade Rating: +13
Spend some time in the boot? Get someone else to shut you in. You might like it then?
Posted: Tue Feb 26, 2013 4:53 pm |
Bump
