Latest: Beduff1977
Overall: 17134
Online Now [434]:
Visitors: 433
Today: 210991
Total: 110065361
Forums › The Car › 206 Problems › manifold fitting
manifold fitting
chief93
PostPosted: Fri Mar 22, 2013 1:17 pm Up
Currently in the process of putting a 4-2-1 manifold on my xsi. ive got the catvoff but what do i need to take off to be able to get the manifold itself off? because the lower bolt in the corner i cant get at? any help much appreciated
1.6 Xsi - Work in Progress!
"If it has wheels or a skirt, it's gonna give you problems."
usher
PostPosted: Fri Mar 22, 2013 2:11 pm Up
Wd40 and persistence you can't leave it and contact risk Sheering it off
current bam project insta
project thread WIP
garage
FAQ
206 gti firedance
chief93
PostPosted: Fri Mar 22, 2013 2:13 pm Up
But i cant get at the nut with anything its the one on the driverside corner at the bottom
chief93
PostPosted: Fri Mar 22, 2013 2:14 pm Up
Do i need to take something else off too to be able to take it off?
lukepug19
PostPosted: Fri Mar 22, 2013 2:34 pm Up
is it the nut behind the pas pump if so had to take mine off its mounting bracket to get at the nut
234re
arronmee1990
PostPosted: Fri Mar 22, 2013 3:19 pm Up
PAS pump and alternator and bracket off before you can get to that one bolt I'm afraid. Although not a hard job
My Project Thread
chief93
PostPosted: Fri Mar 22, 2013 5:27 pm Up
Any chance you could explain how do to do this in more detail? so i know exactly what im doing many thanks!
Zack
PostPosted: Fri Mar 22, 2013 7:07 pm Up
Well on the pas pump on the left side in side the wheel there is 2 Allen key nuts you need to undo if you get stuck PM me your number and I will call you.
Cheers
Zack
PostPosted: Sat Mar 23, 2013 5:48 am Up
I have PM you bud but its in out box
