Latest: tbafonso
Overall: 17130
Online Now [205]:
Visitors: 204
Today: 25808
Total: 103692644
Forums › The Car › 206 Problems › Throttle Issues. Please Help!
vmondude
PostPosted: Fri Mar 15, 2013 10:06 am Up
Ok, so a while back, the head gasket went on my 55 plate 1.4 16v sport at only 29k! So I had it replaced and while they were at it they did a free diagnostic for me before and after, as it was having some acceleration blips as well.
On that diagnostic before it showed the throttle sensor as a fault, but after the rebuild of the head it went away. So we thought bad connection, problem solved.
Anyway, it's back! and before I go replacing the wrong thing, I was just wondering if there was anything else this could be?
It's usually fine, but it just randomly happens (more, recently) where the throttle stops responding for a second or so from the off and then picks up.
Quite Butt clenching at roundabouts, I tell you!
It's also only getting 32mpg av. and I've driven a 1.6 version of the sport that gets 43mpg. Mines apparently supposed to do around 46mpg av. so something's go to be wrong.
So basically, does this sound like the sensor or something else? Your advice on this would be MUCHLY appreciated guys as it's ruining the car to me! Sad
PS would a 1.6 16v sensor still work ok? As I can get one of these cheap...
'55 Peugeot 206 1.4 16v Sport - 17in White Lenso Alloys, Black SP Grille, InPRO LED Rear Lights, Gti Spoiler, Simota Cold Air Induction Kit, Twin DTM Exhaust
vmondude
PostPosted: Sun Mar 17, 2013 11:56 am Up
Are you kidding me!?! 73 page views and not one of you has any idea how to help!
Tolkienfan001
PostPosted: Sun Mar 17, 2013 1:00 pm Up
Trade Rating: +13
The induction kit will reduce your mpg to start with..
2005 1.4 16v Sport
Check out my 206 here!
vmondude
PostPosted: Sun Mar 17, 2013 3:22 pm Up
Funilly enough, it actually went up when I fitted that! haha
Resist
PostPosted: Mon Mar 18, 2013 6:54 am Up
I've had similar problems on my 1.4 GLX. I know it's a different model, but it could be a similar issue.
I cleaned my idle control valve and replaced my MAP sensor and the throttle issues were fixed, and my MPG increased greatly.
Hope this helps.
www.soundcloud.com/resist
vmondude
PostPosted: Mon Mar 18, 2013 1:58 pm Up
Hope this helps.
Oh right thanks for the advice! Very Happy I'll have a look at that before I do anything else.
