Posted: Fri Apr 05, 2013 11:12 am |
Hi basically took my sub and amp out my car yesterday and went to put back in today I connected all the wires and even without the keys in the car the fuse blows straightaway I think I may have mixed a wire round the wrong way but not sure and never done this before and was already in car when I brought it
Posted: Fri Apr 05, 2013 11:30 am |
Stick another fuse in. You could do with checking/testing the wiring for any damage. The ice stupid questions section has a car audio basics guide.
Find an amp wiring guide on here and make sure its right.
Posted: Fri Apr 05, 2013 11:53 am |
I stuck another fuse in and it blow straight away
Posted: Fri Apr 05, 2013 12:10 pm |
Check you connections, Ground ETC Check you power cable it may be cut somewhere, Touching the metal making the fuse blow etc...
Posted: Fri Apr 05, 2013 12:20 pm |
Smokey206 wrote: |
I stuck another fuse in and it blow straight away |
Well you have a short circuit somewhere then.
