Latest: Beduff1977
Overall: 17134
Online Now [724]:
Visitors: 723
Today: 88238
Total: 108023477
Forums › The Car › 206 Problems › Fuel light annoyance (coming on way too early)
nemesislee
PostPosted: Sun Apr 07, 2013 1:10 pm Up
I have had to replace my peugeot 206 LX 1.4 speedo with another one which had the same mileage. the problem is is that the fuel light comes on before it reached the orange low fuel markers at the bottom of the gauge. whats wrong with it? when comparing where the needle reaches on the old one t was slightly lower than the new one?
any help would be great thanks
peugeot 206 silver 1.4ltr lx
PostPosted: Sun Apr 07, 2013 1:44 pm Up
Just put some fuel in it. Cost about a fiver.
mtempsch
PostPosted: Sun Apr 07, 2013 2:13 pm Up
At that time, how much fuel do you estimate there still is in the tank? Is the light or the needle correct?
Where does it point if you brim it? If above the Full mark, then it could be that the needle is simply sitting incorrectly on the axle - probably after someone had to do surgery on the cluster...
Silvermetallic 2004 206 RC
nemesislee
PostPosted: Sun Apr 07, 2013 5:25 pm Up
not sure about brimming it, i checked it against the original and it sits slightly higher tried slighty adjusting the needle but it seems to bounce back to the same position and seems fine. the light did tend to come on before the orange markers on the old one though :S
PostPosted: Sun Apr 14, 2013 8:29 am Up
It needs the software in the BSI updating. Fuel light is accurate, you'll have a gallon or there abouts left.
