Forums › The Car › 206 Talk › Abs sensor |
Posted: Sat Apr 13, 2013 4:15 am |
Does anyone know what type of abs sensor is fitted to the 206hdi 2.0 51 plate I've been told I need new ones and also been told there is 2 different ones thanks
Posted: Sat Apr 13, 2013 5:59 am |
You need pre-plex ones.
Posted: Sat Apr 13, 2013 6:20 am |
Steve206 wrote: |
You need pre-plex ones. |
How do you work that out from it being a 51 plate?
1 September 2001 – 28 February 2002 is when the 51 plate was issued, so lands right on the electrical system change over period.
Posted: Sat Apr 13, 2013 3:18 pm |
I always assumed 2002 onwards was the change.
Posted: Sun Apr 14, 2013 3:23 am |
I'm sure multiplexing was introduced in October 2001.
