Latest: tbafonso
Overall: 17130
Online Now [380]:
Visitors: 380
Today: 72301
Total: 102809242
Forums › The Car › 206 Problems › Help
Help
Rob206
PostPosted: Sun Apr 28, 2013 2:04 pm Up
Hi my car has been making a grinding squeeking noise mainly when I turn but does it all time wanting to no what it is has I have next weekend off and would like to sort it
PostPosted: Sun Apr 28, 2013 2:32 pm Up
Could be a hundred things. CV joints, top mounts, bottom arms knackered.
Rob206
PostPosted: Sun Apr 28, 2013 2:43 pm Up
Ok mate where would be the best place to start do you think
DREWDEN
PostPosted: Sun Apr 28, 2013 2:44 pm Up
Does steering feel heavy, or is normal
206 2ltr Hdi glx 53 plate
Rob206
PostPosted: Sun Apr 28, 2013 2:56 pm Up
Little but heavier come to think off it mate
DREWDEN
PostPosted: Sun Apr 28, 2013 4:06 pm Up
Whilst stationary engine running obviosly, turn your lock fully left then fully right, see if there's any grinding and squeeling going on.
Rob206
PostPosted: Sun Apr 28, 2013 4:11 pm Up
It's like a grinding mate and it does it when you go over little bumps down road but really bad when turning
DREWDEN
PostPosted: Sun Apr 28, 2013 5:01 pm Up
I was just eliminating the wheel bearings and other stuff thats all, if you test the steering when stationary and you still get the grinding it would point me to check steering fluid or steering box, if you don't get the noises then somethings making the noise whilst driving.
PostPosted: Mon Apr 29, 2013 1:20 am Up
More than likely top mount bearings if it happens when stationary.
Rob206
PostPosted: Mon Apr 29, 2013 1:28 am Up
It's like a grinding mate and it does it when you go over little bumps down road but really bad when turning but just checked steering when stationery and it doesn't do it
PostPosted: Mon Apr 29, 2013 3:19 am Up
Sounds like bottom swivel joint or wishbone to me.
Rob206
PostPosted: Mon Apr 29, 2013 4:07 am Up
Are they easy enough to do
DREWDEN
PostPosted: Mon Apr 29, 2013 6:12 am Up
Check for any play in your wheel bearings front/back
Rob206
PostPosted: Mon Apr 29, 2013 6:42 am Up
It's wasn't that long ago it had new wheel bearings put on it
