Latest: Beduff1977
Overall: 17134
Online Now [530]:
Visitors: 529
Today: 124984
Total: 109691651
Forums › The Car › 206 Problems › Raditor and fan assembly, mix and max?
MrMorris
PostPosted: Mon Apr 29, 2013 9:02 am Up
Hello all, quick question.
Will an radiator and fan and aircon lot fit into a 2.0 gti 138... its from a 1.6 rolan garros 206.
Cheers lads. It looked identicle to me.
MrMorris
PostPosted: Mon Apr 29, 2013 1:10 pm Up
29 views 0 replies Sad
I take it this is a stupid question Sad lol, know sod all about engines.
Please someone, a simple yes or no will suffice. Got a man waiting to know if I want this new fan, motor and aircon cylinder.
Thank you in advance! Smile
PostPosted: Mon Apr 29, 2013 2:06 pm Up
It should fit...although the radiator on a 1.6 might be smaller than the GTi.
MrMorris
PostPosted: Mon Apr 29, 2013 2:16 pm Up
Thank you, I think I might just buy it and hope for the best, he only wants £25 so if it dont work ill sell it on ebay or something.
I just wondered if any of the hoses or connections would be different?
Thank you again.
