Latest: Puggingalong
Overall: 17129
Online Now [340]:
Visitors: 339
Today: 49258
Total: 101744186
Forums › The Car › 206 Talk › power steering
power steering
bigdave987
PostPosted: Sat May 04, 2013 12:41 pm Up
this is my first gti 138 and the power steering feels quite heavy compared to other cars ive had can anyone give a rough idea on roughly how heavy this should be as ive read that they are a bit heavier for handling purposes ta.
PostPosted: Sat May 04, 2013 12:43 pm Up
The 206 power steering is heavier then Vauxhall / Ford stuff of the same age, its just the way they are.
bigdave987
PostPosted: Sat May 04, 2013 12:47 pm Up
oh okay ta for the rapid response thought i was going to have to start hunting down a fault!
gtijames22
PostPosted: Sat May 04, 2013 1:14 pm Up
yeah they are pretty heavy, if there's no abnormal noises coming from the pump then its fine, just keep an eye on the level tho Smile
GTI 180 JIM
PostPosted: Sat May 04, 2013 4:06 pm Up
Electric pump from a Saxo makes the steering a bit lighter...but would also need a few other things changing to fit it.
