Latest: Puggingalong
Overall: 17129
Online Now [286]:
Visitors: 285
Today: 12790
Total: 101219981
Forums › The Car › 206 Problems › Left Dip beam does not work
Alexi1751
PostPosted: Sun May 12, 2013 4:10 am Up
Hi there I am new to the forums and I need assistance
I looked for topics like this but none came up on my search
The problem is that I have recently installed new after market headlights for my
2003 1.6 16v quicksilver but after instillation all the lights work bar from
the left dip beam....
I have tried using different bulbs(H7only fit) and know that it is not
the lighting unit as it works on the other side.
How ever engine fuse box fuses F9 & F10 only one of them
Is receiving power as when I remove 10 right dip goes off.
Replacing F9 does nothing there for is it the relay??
Or am I missing something completely easy to fix
PostPosted: Sun May 12, 2013 4:48 am Up
What happens with your old lights in?
Alexi1751
PostPosted: Sun May 12, 2013 4:51 am Up
Old lights are out of the question previous owner did an awful job of fitting, I believe he knew
of this problem and bridged power from the right hand side hence there was a wire running
across the bonnet, but I want to resolve this problem
iainlovatt
PostPosted: Sun May 12, 2013 5:40 am Up
Bad earth on the light? Is there power getting done the cable? Follow the cable to see if there is any breaks!!
(My Garage)
PostPosted: Sun May 12, 2013 5:58 am Up
So you only told us half the problem?
Sounds like your wiring is at fault then, do as ian said and trace all the wires.
Alexi1751
PostPosted: Sun May 12, 2013 6:13 am Up
Ok fixed it traced the orange dip wire back thanks Ian there was a bad connection between that and the fuse box and used my electro meter to gauge whether power was coming through at both sides
Thanks for your help how do I get set this as solved ??
