Online Now [53]:
Visitors: 52
Today: 2323
Total: 104930045
Forums › The Car › 206 Problems › Wrong size tyres fitted...
longshortchris
PostPosted: Sun May 12, 2013 12:37 pm Up
I have owned a 2002 2.0 HDi 3 dr for twelve days now & I realised last week that I have the wrong wheels and/or tyres fitted.
I've checked online & I know I should have 195/55/15 tyres but I don't. The car currently is sporting 4x 205/50/15 tyres on alloys looking something like 307 87 sports wheels, it that make sense?
Why anyone would put on a tyre with a smaller circumference beats me!
But, I want to know, can I just put original spec. 195/55/15 tyres on my current alloys? I haven't measured them just in case someone here know that I can simply swap the tyres for the correct ones.
Chris
macj
PostPosted: Sun May 12, 2013 12:57 pm Up
yes you can...... thing is, Do you need to unless you have worn them out. They have a very similar rolling radius so it wont affect your speedo. I assume they don't rub on your arches so keep em until they wear out
longshortchris
PostPosted: Sun May 12, 2013 1:12 pm Up
Thanks macj.
I was planning on keeping them until they wear out. The garage did say they had about 4k left on all of them. Then, I'll change them as and when needed.
Being smaller in circumference, by 1cm, means that for every 100 rotations of the tyres, I'm going backwards 3.14 metres. Not literally, but I'm sure you understand wot me sayin'! That's not good for economy as neither is the extra grip.
That's another thing checked off. Only about a dozen to go...
Chris
PostPosted: Mon May 13, 2013 3:46 pm Up
This page says smaller by 1cm (10mm) diameter - note diameter NOT circumference.
www.tyresave.co.uk/tyresize.html
and calculating circumference here
math.about.com/library...ulator.htm
195/55/15 = 196mm dia = 1872.39 mm circumference and
205/55/15 = 186mm dia = 1840.97 mm circumference.
So being smaller circumference compared to old tyres 10,000 real kms will record now record an extra 170kms.
To get a perfect matching circumference the tyre new size in a 50 profile needed to be 215/50/15. There may be many reasons for not doing that like cost, availability or wheel width.
PostPosted: Mon May 13, 2013 3:58 pm Up
Using pp2000 you can set the tyre size so your speed and mileage is worked out correctly.
