Online Now [299]:
Visitors: 298
Today: 15887
Total: 105024300
Forums › The Car › 206 Problems › spare wheel cage bolt
kizza93
PostPosted: Thu May 23, 2013 5:38 am Up
how do i remove the bolt i have a new one the old one is rusted ive tried wd40 but wont budge any ideas?
PostPosted: Thu May 23, 2013 5:50 am Up
Cut it of.
kizza93
PostPosted: Thu May 23, 2013 6:44 am Up
thanks for that i ment with what i dont have acsess to a angle grinder
karlfaber2012
PostPosted: Thu May 23, 2013 6:53 am Up
Hacksaw ?
eddie206
PostPosted: Thu May 23, 2013 8:55 am Up
If your still stuck and youve tried a really good lever on the boot end once the wd40 soaked in try this...
the spare tyre in place will allow some give and the end of the bolt is a hook sort so try jacking up the cradle near to the bolt and once the slack and play is taken right up you should be able to prize the hook end over the cage and drop the cradle down...now you have access to cut the bolt off easily..
