Online Now [77]:
Visitors: 76
Today: 1134
Total: 106047018
Forums › The Car › 206 Problems › 206 1.4 04 plate problems
daniboy123
PostPosted: Tue Jun 04, 2013 10:18 am Up
Hi there, my sisters car has flagged up the following errors and now wont start;
P1336
P0170
Can anyone tell me what these codes mean and what needs to be checked/tested please?
James206.52
PostPosted: Tue Jun 04, 2013 10:23 am Up
P1336 Crank/Cam sensor range/performance
p0170 fuel trim malfunction bank1
quick search on the internet found these... hope it helps at all Smile
PostPosted: Tue Jun 04, 2013 10:40 am Up
Fault Code List - aka What can go wrong
daniboy123
PostPosted: Tue Jun 04, 2013 1:07 pm Up
I managed to find the faults and have replaced the crankshaft sensor to no avail. In the haynes manual it states that the ECU operates on a wasted spark principle so i assume it doesnt have a cam shaft sensor if anyone can confirm this?. As far as the other fault goes could this be an O2 sensor issue? would it flag this fault if the engine was running too lean/rich meaning there is a fuel supply problem. What does bank 1 refer to? Thanks.
Brendanmidds
PostPosted: Wed Jun 05, 2013 4:22 am Up
bank 1 normally refers to 2 lots of sensors and bank 1 being the 1st and bank 2 being the second and does normally go on the lambda sensors, it should have a cam shaft sensor located on the belt end normally.
hope this helped.
