Latest: airmastertapes
Overall: 17133
Online Now [76]:
Visitors: 75
Today: 23910
Total: 106884511
Forums › The Car › 206 Problems › 1.4 HDI Cambelt Question
Ferdasyn
PostPosted: Sun May 19, 2013 8:37 am Up
Hi Guys,
After last service on my 206 in March I was told to replace the timing belt within the next year, preferably by October to be safe. Just this morning I heard a rattling and noticed part of the belt has worn/snapped, but most of it is still intact.
Obviously this will need replaced, but my question is will the belt be sufficient or should I go for the whole kit & water pump? I appreciate you probably won't b able to say much without seeing it but I don't know an awful lot about engines or parts so I'm kind of in the dark.
PostPosted: Sun May 19, 2013 8:48 am Up
You better hope it hasn't jumped a tooth if it's rattling.
But did you take the plastic cover off, or are you simply looking at the external V-belt instead?
Definately the whole lot straight-away.
iainlovatt
PostPosted: Sun May 19, 2013 8:51 am Up
the whole lot buddy! The amount of 206's on here that have had cambelt failure is unreal! Not worth any risk! Get it booked in for tomorrow. How do you intend on getting it to the garage?
(My Garage)
Ferdasyn
PostPosted: Sun May 19, 2013 8:57 am Up
I suppose I could get someone to tow it. A friend has offered to change it if I source the parts - would you recommend this kit?
www.ebay.co.uk/itm/Day...vi-content
Perfect bloody timing as well, going on holiday in a fortnight!
iainlovatt
PostPosted: Sun May 19, 2013 9:16 am Up
I agree get it towed! or get the garage to come pick it up if they are local.
(My Garage)
Ferdasyn
PostPosted: Sun May 19, 2013 9:36 am Up
Its not far away at all (2 mins down the road) so that shouldn't be a problem. Noticed it doesn't actually have the cambelt cover so Ill try and find one of those as well.
Ferdasyn
PostPosted: Sun May 19, 2013 11:35 am Up
Good news (I guess) - It's not the cambelt, its the aux belt. Less of a worry! Managed to get it down to the garage, hopefully have it back up and running soon enough!
PostPosted: Sun May 19, 2013 3:31 pm Up
Get the timing belt done or it really will be bad timing.
Ferdasyn
PostPosted: Fri May 31, 2013 10:13 am Up
Will have the timing belt done in the next two months or so. Quick question; It saying Im due a service in 3500 miles or so, what will that entail? It's a 1.4 HDI and its done 98k already.
