Forums › The Car › 206 Talk › ask :206 GTI VS 180 VS OTHERS LOWER ARM |
Posted: Sun Jun 09, 2013 10:30 am |
Some did tell me they had diff of balljoint on Gti while bushes on 1.4 and 1.6
can someonepost picture as comparison
thank you in advice
Posted: Sun Jun 09, 2013 12:12 pm |
ebay/eurocarparts/gsf
| Joined the GTi massive 10/1/13
Goodbye lairy Pugani (quicksilver 1.4)  | |
Posted: Sun Jun 09, 2013 12:57 pm |
Ball joint isn't different but the other bushes are.
