Posted: Tue Jun 25, 2013 3:32 am |
I've got a 1.4hdi 2002 when the engine reaches 3000 revs it losers power. I've had a local mechanic have a look he's tried different sensors but with no luck. He doesn't seem to know problem as anybody come across this before.
Posted: Tue Jun 25, 2013 5:39 am |
I would be tempted to look at the fuel system side of things.
filter, injectors, pump.
Any warning lights on dash at all.
| 206 2ltr Hdi glx 53 plate | |
Posted: Tue Jun 25, 2013 7:57 am |
The engine management light is on but he said it showed something about heater plugs but that would not be problem. One of the sensors he changed I was told was something to do with drive shaft but that did not cure it.
Posted: Tue Jun 25, 2013 8:21 am |
sounds like the engine limiter to me have you checked that it has got one as its a diesel
Posted: Tue Jun 25, 2013 9:31 am |
U need the codes reading before you spend any more money.
Posted: Tue Jun 25, 2013 2:47 pm |
eddie206 wrote: |
U need the codes reading before you spend any more money. |
Posted: Tue Jun 25, 2013 4:24 pm |
Surely the mechanic must have code read it, before he messed around with swapping sensors.
Obvious first step for any mechanic i would have thought, or at least an electrician to test the sensors.
Posted: Tue Jun 25, 2013 6:30 pm |
Im guessin as he says local mechanic that he will work without the code reading stuff just doing it oldskool...
Posted: Wed Jun 26, 2013 9:27 am |
He code read it but he said it was something to do with heater plugs which he said wouldn't cause this problem
Posted: Wed Jun 26, 2013 10:04 am |
Neilsharon1990 wrote: |
He code read it but he said it was something to do with heater plugs which he said wouldn't cause this problem |
Find someone that KNOWS what there doing & talking about
