Posted: Fri Jul 05, 2013 5:08 pm |
Trade Rating: +59
| Addaz wrote: |
| Some of the ideas eddie206 is throwing out nowadays........ |
Edited for accuracy and truth.
| '98 Nile Blue 306 GTi 6
'04 Obsidian Black 206 GTi 138 | |
Posted: Fri Jul 05, 2013 5:26 pm |
| Addaz wrote: |
| Some of the ideas people are throwing out nowadays......... I would be checking fap pressures, boost lines for turbo failure (oil blocking them) and see if the ecu is unlocking |
There could be numerous issues causing it, if it died while you were driving it then were there any prior issues? Did the revs drop suddenly before it died? Did anything strange happen before it died? Best thing to do is get the error codes read.
Not sure if I am taking out of my a**e here or not, but it would still start with a faulty turbo, and just cut out when you give it a good amount of revs, no?
Not 100% sure, never owned or worked on a car with a turbo, never needed the knowledge
| Cherry Red 206 1.1 99'
Wanted List;
Crystal Headlights.
PM Me if you are selling! | |
Posted: Fri Jul 05, 2013 5:45 pm |
If this situation had happened to me, my first port of call would have been to clean the engine dipstick, and dip the fuel tank, to see where i was with the diesel.
I assume the car as been sorted now, and hopefully she can say what it was.
| 206 2ltr Hdi glx 53 plate | |
Posted: Sat Jul 06, 2013 6:48 am |
EXCUSE ME HERE..IS THIS A CONSPIRACY OR WHAT?????
ADDAZ DOESNT EVEN SAY"SOME OF THE IDEAS EDDIE206 IS THROWING OUT"???
WHAT ARE YOU SAYING???OR IS THAT THE EDITED VERSION???
AS FOR STRANGE IDEAS..AS FAR AS MY COMMENT WENT.......I SUGGESTED PUTTING £5 OF DIESEL INTO THE CAR..THEN I SAID TO PUMP THE LIFT PUMP LIKE THE GUY ABOVE MY FIRST COMMENT HAD STATED...
THIS IS PERSECUTION AND IM DUE AN APOLOGY I BELEIVE...IF NOT FROM EDITOR THEN FROM ADDAZ...ONE OF WHOM IS WRONG HERE....COME ON FELLAS SORT IT OUT...
Posted: Sat Jul 06, 2013 6:54 am |
At least this is a new forum record for a 1.6 HDI breaking down after purchase
Posted: Thu Jul 11, 2013 5:36 am |
Hello
Thanks for all your replies. The ECU connections were loose, apparently!!!
Runs fine now
Posted: Thu Jul 11, 2013 5:42 am |
| eddie206 wrote: |
THIS IS PERSECUTION AND IM DUE AN APOLOGY I BELEIVE...IF NOT FROM EDITOR THEN FROM ADDAZ...ONE OF WHOM IS WRONG HERE....COME ON FELLAS SORT IT OUT... |
Don't hold your breath, or do. Either way.
BTW, fix your keyboard.
Posted: Fri Jul 19, 2013 5:59 pm |
YAY you've beaten my record! LOL
I have got an issue, but its not directly connected to a 1.6 hdi
To be fair, mine apart from the DPF issue has been fault free, apart from electrical issues which pugs are known for.
