Latest: tbafonso
Overall: 17130
Online Now [96]:
Visitors: 95
Today: 37368
Total: 103773153
Forums › The Car › 206 Problems › Rear Clunking Noise....
tris_asd
PostPosted: Tue Jul 09, 2013 5:47 am Up
I've had a clunking noise coming from the rear for a few months. It tends to only be noticeable when driving slowish and potholes obviously bring it on. So on the roads round here, driving slowly, it doesn't sound great.
I've jacked it up and had a waggle and everything seems to be solid. No play at all that I can notice.
I did notice this bush that looks like the rubber may not be totally intact. However I noticed the rubber is the same on the other side so I'm guessing it's not this. The rubber only goes around 80% of the bush and then stops which I thought was a little strange.
Anyway, I doubt this is causing the clunking but anyway of diagnosing what the issue is? I've heard the rear axles go on these 206's fairly frequently, or could it be ARB related? Thanks
cc
PostPosted: Tue Jul 09, 2013 10:05 am Up
Either the rear shocks are shot, or their mounting bolts have become loose or their mounting bushes are worn.
But I recon shocks.
