Online Now [49]:
Visitors: 49
Today: 29488
Total: 105037872
Forums › The Car › 206 Problems › Curious Rattling
Curious Rattling
JayH04
PostPosted: Wed Jul 17, 2013 6:12 pm Up
Hi guys,
Just a query about my 206 1.1L engine.
When I start the car for the first time of the day, or when the engine is cold, I hear a rattling and the engine sounds quite ropey.
As I don't know much about mechanics (at all), this could be completely normal and I could be curious about nothing. But the noise dissapears after 5-10 minutes of driving (or when the engine temperature gets up to or past 70c).
Btw, the noise can only really be heard when the engine is idle.
Any suggestions?
Cheers guys Smile
3-Door 206 1.1L LX in Metallic Silver 2003 REG Wink
Tolkienfan001
PostPosted: Wed Jul 17, 2013 11:30 pm Up
Trade Rating: +13
Heat shield most likely....
2005 1.4 16v Sport
Check out my 206 here!
JayH04
PostPosted: Thu Jul 18, 2013 9:34 am Up
Any guidance as to how I may go about fixing this or if it is a worry?
Cheers Smile
Tolkienfan001
PostPosted: Thu Jul 18, 2013 11:18 am Up
Trade Rating: +13
I may do after this weekend. Mine is doing it too. I am going to jack the car up climb under the car and start knocking and rattling things until I find it......
2005 1.4 16v Sport
tommyb32
PostPosted: Fri Jul 19, 2013 5:43 am Up
yeah most probably the heat shield. I have it on mine too and god its annoying
peugeotgti
PostPosted: Sat Jul 20, 2013 7:44 am Up
Start the car and move around the engine holding things down with a big screwdriver until you spot what is rattling as it goes quiet when pressed with tool..once you find it you can tigjten it up if possible or add some washers or similar depending where you find the rattle?
PostPosted: Sat Jul 20, 2013 7:56 am Up
When was the last time the tappets where checked / adjusted?
