Forums › The Car › 206 Problems › 206 starter motor help, newbie here |
Posted: Sun Aug 25, 2013 6:42 am |
hi all, im new here and need some help
im looking at buying a 2002 206, however the engine has been replaced from a 1.4 to a 1.4 from a 306, however the starter motor makes a crunch when it starts, once started the car drives fine, the seller a mechanic has re assured me the fly wheel is fine and that the 306 engine has a 206 starter motor and it needs the bigger 306 starter, however looking on euro car parts etc the starter motor for a 206 and 306 are identical ? according to the spec.
there could be a chance the original 206 starter was the wrong one for that car however I am abit wary
any help would be appreciated, Nathan!
Posted: Sun Aug 25, 2013 7:10 am |
Might look the same, but the starter teeth could be different. Whay didn't he replace with a 1.4 206 engine? I would give it a miss tbh, plenty of cars available.
Posted: Sun Aug 25, 2013 7:12 am |
just the engine that became avaliable to him, says same number of teeth, same number of mounting holes and length, he also said there are two types of starters for 1.4 so never no with out comparing both ?
Posted: Sun Aug 25, 2013 10:43 am |
Anyone else have any ideas?
