Posted: Mon Jun 30, 2014 8:16 am |
Other than the obvious driveshafts and bolts securing the gearbox to the engine, does the 206 require subframe removal to get the 'box out?
Looking to change the clutch next week (inc a new cable) and don't wanna messing around with the subframe!
Regards,
Jim
Posted: Mon Jun 30, 2014 8:29 am |
Nope. Just lots and lots of bolts! the drivers side driveshshaft can be a bit of a pain to separate from the box. Straight forward though..
Posted: Mon Jun 30, 2014 8:56 am |
Sweet. Thanks mate. I've changed a drivers side shaft on my 1st GTI, with the extra support and 3 tiny bolts.
Shouldn't take long!
Jim
Posted: Mon Jun 30, 2014 11:28 am |
| GTi137 wrote: |
Looking to change the clutch next week (inc a new cable) |
Good luck looking for the cable, right hand drive 206 GTI is a hydraulic clutch set up.
Posted: Mon Jun 30, 2014 11:58 am |
As I hadn't had the opportunity to research it further, you've saved me the bother.
Posted: Mon Jun 30, 2014 1:18 pm |
Get a new slave cylinder while your at it!
