Posted: Tue Oct 15, 2013 5:21 pm |
Hi guys,
I've just bought my first car - bright red W reg 1.1. It's the most basic model.
Now, my issue is it only came with 1 key, so I'm looking to get another cut. Does anyone know if this'll be as simple as popping in to Timpson's and asking them to cut another one?
Cheers,
Db
Posted: Wed Oct 16, 2013 1:08 am |
Welcome to the forum.
You will need to get the key cut properly by a shop that does car keys, as you will need an immobiliser chip programming too
Posted: Wed Oct 16, 2013 2:12 am |
Not sure if Peugeot still sell pre plex remotes.
Your best bet is to either go to an auto locksmith who can clone the original,
or get a second hand fob (2 types Deadlocking and non-deadlocking) with blank blade from ebay, then find someone with PP2000 to program a virgin transponder chip and pair the remote to the car. You'll need the security code for this.
The only other option is to go into a dealer and ask them for a new key. They will supply it already cut using the keycode, and then you'll just need to pay to have it set up to the car. I wouldn't expect much change from £120 for this though.
Posted: Wed Oct 16, 2013 3:08 am |
Timpsons charge £40 quid for sorting a key out. This will be a basic one without a button for central locking.
I would find out if anyone has peugeot planet around near you. That way you could pay them a small amount of cash for them to pair the immobiliser chip to your car.
Posted: Wed Oct 16, 2013 9:02 am |
Or contact lee and he'll post you a chip pre-programmed.
Early keys come in different versions so you have to get one that matches the original ... check the circuit board, etc. or it won't programme via pp2000.
