The carpet on the passenger side is wet just below the seat i have no idea where its coming from, ive checked the door holes at the bottom of door and there clear.I have no sunroof and door card hasnt been taken off
Any help please
Cheers
check the doors seal above the wing mirror mine spilt before and also the courtesy light as my aerial leaks in a little bit and it lands on the gearstick if your on a slant itll be on the carpet
I had exactly the same issue, I couldn't trace where it was coming from so I made a hole in the bottom of the door seal as I figured I would have to replace it anyway, so far no more water has come into the car.
Interactive software released under GNU GPL,
Code Credits,
Privacy Policy
