Latest: tbafonso
Overall: 17130
Online Now [105]:
Visitors: 104
Today: 9790
Total: 102084124
Forums › The Car › 206 Talk › 180 manifold fit gti?
w343nna
PostPosted: Wed Jan 15, 2014 5:53 am Up
Will a gti180 manifold fit a normal gti?
L5_UKS
PostPosted: Wed Jan 15, 2014 6:08 am Up
Yes
206info.co.uk/Forums/v...ifold.html
206gt160
PostPosted: Wed Jan 15, 2014 6:09 am Up
Yes it will, I have done it on my 206 gti. is your throttle body cable or electronic?
1999 206 Gt... Gti180 inlet, Gti180 exhaust manifold, Gti180 injectors, Gti-6 throttle body, Custom Adapter pipe to mate the throttle body to intake, Gti180 alternator, Gti-6 ICV, Straight through stainless exhaust system, cat cams (apparently), Avo coilovers, short shift gear stick, stripped out with fixed back bucket seat and harness, flocked dash, momo steering wheel and D2 solid boss, real carbon cold air intake, Gti-6 front calipers and 288mm disks, rear drilled and grooved disks, morette headlights, sp bonnet grill 71,456 miles
2008 Audi A3 2.0 Tdi 170
w343nna
PostPosted: Wed Jan 15, 2014 6:20 am Up
Cable throttle
w343nna
PostPosted: Wed Jan 15, 2014 6:21 am Up
Sorry iv not worded this right, I mean exhaust manifold
206gt160
PostPosted: Wed Jan 15, 2014 7:04 am Up
yes that will also fit but i think the exhaust ports on the 180 are slightly bigger, I have the 180 exhaust and inlet on mine.
w343nna
PostPosted: Wed Jan 15, 2014 7:18 am Up
Brilliant thanks, My local scrappy has a 180 manifold cheap, my standard one has a really annoying rattle also pondering the intake manifold now! Anyone have one for sale any proven power figures of fitting both?
PostPosted: Wed Jan 15, 2014 8:03 am Up
and you need the gear linkage too.
w343nna
PostPosted: Wed Jan 15, 2014 11:18 am Up
I need a gti 180 gear linkage to fit the exhaust manifold?? I'm purchasing constella uprated ones will these do the trick ? Can you explain why? Does it hit the manifold ?
PostPosted: Wed Jan 15, 2014 11:22 am Up
The 180 runs a cable linkage, the 138 rod set up will hit the manifold.
Lex206
i also think the exhaust ports on the 180 are bigger,so if you put the 180 exhaust on a gti head the ports wont match.
you have to adjust the ports of the gti to the larger 180 exhaust.
Megane 225 RS
PostPosted: Wed Jan 15, 2014 3:37 pm Up
If the 180 manifold ports are bigger than the 138 head ports it will be fine.
Kale
PostPosted: Thu Jan 16, 2014 10:07 am Up
And a thing that would be wise to check (I'm not sure about this) is that can you fit the gti front pipe to the gti180 manifold. Is the connection between them at the same place and is the pipe diameter different.
Rattling GTI manifold is quite easy to fix, remove the front pipe from the exhaust manifold and tack weld the four pipes inside the manifold together.
Picture of a welded manifold
Though.. It can be hard to reach when the manifold is in place..
This is a common problem on all the regular EW engines.
306 S16, 306 GTI-6, 605 SV24, 205 GTI-6, 2x405 Mi16, VW T3 1.9TD/AAZ, Audi TT mk2 3.2 quattro, Audi A6 2.7 biturbo quattro
