Latest: flipflap
Overall: 17140
Online Now [242]:
Visitors: 241
Today: 64054
Total: 113864033
Forums › The Car › 206 Problems › Fuel gauge dashboard issue
206HdiGti
PostPosted: Thu Jan 30, 2014 11:01 am Up
2005 gti hdi 110
I put 30 litres of diesel in last night.
This morning it said I had 567 miles remaining.
Got to work, 17 miles later, I had 345. Turned car off.
Turned car on, went to site, 3 miles down the road, i've got 415. Turned ignition off.
Went back to work and i've got 560 again.
Is the speedo/fuel gauge a common problem?
Lecktorious
PostPosted: Thu Jan 30, 2014 11:19 am Up
Trade Rating: +59
The gauge is crap. Just use the trip counter if you want to see how many miles you are getting out a tank, or use the fuel gauge if you want to see how much you have left.
'98 Nile Blue 306 GTi 6
206HdiGti
PostPosted: Thu Jan 30, 2014 11:20 am Up
The fuel gauge is going up and down depending when I turn the ignition on and off so the trip is wrong as well...
RichardEke
PostPosted: Fri Jan 31, 2014 11:55 am Up
I think Lecktorious was meaning fill it up to full, then reset your trip computer.
Next time you fill up (has to be upto full) see what the trip says. Then you know how many miles you've covered and the fuel used.
Miles/gallons used = MPG
Doesn't help solve your issue but its how i worked it out with my lower spec 206.
Ps - 4.545 litres in a gallon.
Regards, Richard.
PostPosted: Fri Jan 31, 2014 12:09 pm Up
Have you tried the obvious?
BSI reboot and failing that go to Peugeot to get the software updated
