Latest: SA01
Overall: 17138
Online Now [251]:
Visitors: 250
Today: 1858
Total: 112226376
Forums › The Car › 206 Talk › external oil coolers
123nathan0g
PostPosted: Sat Feb 15, 2014 3:53 pm Up
as above, peoples opinions on them ? im tempted, just for looks either a small 5/6 inch one or a massive 30cm one,
im going down the rat look but not rat look if that makes sense haha, low, steels, maybe a roof rack blah blah lol
Nathan
PostPosted: Sat Feb 15, 2014 4:46 pm Up
My opinion is if you need one then fit one. If its not needed then don't.
If you want the looks then fit it but don't plumb it in. Which is utterly pointless. Most 206's won't need one anyway.
PostPosted: Sat Feb 15, 2014 5:03 pm Up
My thoughts are what a waste if time....& no I don't get it.
PostPosted: Sun Feb 16, 2014 11:52 am Up
Unless the engine is highly developed, dont bother. I only fitted a small 12 row due to the fact it now has a turbo. Dont forget you will need an oil thermostat otherwise it could cause you serious issues!
