Latest: S2cgm
Overall: 17178
Online Now [132]:
Visitors: 131
Today: 2694
Total: 135897963
Forums › The Car › 206 Problems › Gti180 coolant bleeding
gogs_macaulay
PostPosted: Fri Feb 21, 2014 6:25 pm Up
how do you bleed a 180 cooling system? is there only two bleed screws?
SinfulDesignCom
PostPosted: Fri Feb 21, 2014 7:47 pm Up
Yes, one from heater matrix - black plastic thumbscrew type, and one by thermostat to the right of the cylinder head.
Rad cap off, heater on maximum, let her run to temperature and bleed in turn. Check a few times as air takes time to circulate depending on how much is in the system. Make sure fan comes in and out, might stay on longer at first, but should cut out after a few seconds when bled correctly depending on ambient temperature.
Finally, make sure you check your coolant level as you are bleeding, and then again after a few runs when complete as it will most like have dropped.
Sinful Design - web design, graphic design, web apps, hosting...
My 2003 GTi 180 Track Project Thread
