Latest: tbafonso
Overall: 17130
Online Now [554]:
Visitors: 553
Today: 26959
Total: 103994863
Forums › The Car › 206 Problems › non starting quicksilver
HOLES
PostPosted: Mon Mar 10, 2014 1:34 pm Up
Ok so my friends 1.4 8v quicksilver (y plate preplexed) wont start.
there is a clicking from the fuel pump relay (which we replaced with a brand new item), still clicks when ignition is turned on. The coilpack isnt getting any power to produce a spark and the fuel pump isnt priming/running. We tried to wire a direct power source to the pump once we removed it from the system and it works fine, just doesnt seem to be getting a signal when to do its thing when its in its place. we also tried the bsi reset procedure and that has done nothing. Somone on a google search said to check earth leads, so did that but their all fine.
there hasnt been anything leading up to it, it just wouldnt start one morning.
any ideas what the issue could be? Could it be immobiliser issue? Any ideas on anything more we could check off?
PostPosted: Mon Mar 10, 2014 1:54 pm Up
My first thought was the immobiliser. Has he got a spare key he can try?
HOLES
PostPosted: Mon Mar 10, 2014 1:58 pm Up
How would spare key make a difference? Not being an ass with an attitude, im asking genuinely.
HOLES
PostPosted: Mon Mar 10, 2014 2:00 pm Up
No he only has the 1 key for it
Because the immo chip inside the key can go faulty
HOLES
PostPosted: Mon Mar 10, 2014 2:50 pm Up
Ah right. No unfortunately he only has the 1 key
HOLES
PostPosted: Tue Mar 11, 2014 2:52 pm Up
Any ideas bump?
