Posted: Fri Aug 01, 2014 2:14 pm |
Thanks for the add to the group...first post on here. Not long had our 206 and just found a bad leak, turns out its the steering rack, a common problem according to our little garage, quoted around the £350 mark for them to replace.....does this sound about right and in the meantime has anyone used any stop leak with good or bad results, cheers
| | ![](images/spacer.gif) |
Posted: Fri Aug 01, 2014 3:08 pm |
I've never used stop leak just always kept a bottle of fluid on my car when the ford had it's leak.
£300 is a good figure for a rack replacement
Posted: Sat Aug 02, 2014 1:35 pm |
yer that's about right for a recon rack and fitting
Posted: Sat Aug 02, 2014 2:52 pm |
a replacement is the best choice here,save time and money.
Posted: Thu Aug 07, 2014 3:33 am |
I have same leak problem. seems to be coming out near drivers side. I asked my mechanic about the stop leak stuff and he said it was 'worth a try' . Think it may have slowed it down a bit but will need to get the root of the problem sorted as my other half it going off her nut about the state of her driveway ![Smile Smile](images/smiles/icon_smile.gif)
