Posted: Wed May 14, 2014 7:53 am |
Hi, I have a Peugeot 206 1.4 petrol (2003 - around 100000 miles).
My Amber Engine Management Light came on so I got it scanned and it came back with the errors:
P0110 - Intake Air Temperature Sensor 1 Circuit
P0170 - Fuel Trim Bank 1
P0120 - Throttle/Pedal Position Sensor/Switch A Circuit
P0105 - Manifold Absolute Pressure/ Barometric Pressure Circuit
My car is also running rich, I can smell it from the engine and I only get 200 miles to a full tank.
Any advice would be helpful.
Thanks Stephen
Posted: Wed May 14, 2014 8:23 am |
Have you cleared the codes and seen what has come back? Sounds like a possible map sensor though!
| Team Impossible Possible
Posted: Wed May 14, 2014 8:47 am |
Hello, I originally only got the 'P0170 - Fuel Trim Bank 1' fault code - which I cleared and after 180 miles of driving, the light came back on but with the 4 codes instead.
I am going to replace the MAP sensor soon but would this really cause the other codes?
