Latest: S2cgm
Overall: 17178
Online Now [81]:
Visitors: 80
Today: 48414
Total: 137399570
Forums › The Car › 206 Problems › VIDEO UPLOADED 10/05/14 - Oil light low revs issue continues
Go to page 1, 2, 3, 4, 5, 6  Next
Tolkienfan001
PostPosted: Mon May 13, 2013 9:07 am Up
Trade Rating: +13
Just parked the car up radio (standard orm) on drivers window slightly open. Turned the key off. Locked the car and left it for 10 mins.
Went back to the car unlocked it via the remote. Started the car up the radio came on as it should however the mfd did not display the radio info and the radio was emitting a high pitched constant beep over the radio. Very loud.
No warming lights on the car etc.
I turned the car off the radio stayed on playing but beep stopped. I turned the car on the radio continued but the mfd came on properly and now it is ok again.
Anyone have this happen before? Is it related to my other posts regarding the random beeping and oil light and earth strap.
Have I got more earth problems or some other electrical issue.
The battery is 100% and only 5 months old. It has been tested.
Thanks in advance
2005 1.4 16v Sport
Check out my 206 here!
PostPosted: Mon May 13, 2013 9:12 am Up
Have you got any LED lights fitted?
Any HID stuff?
Tolkienfan001
PostPosted: Mon May 13, 2013 9:18 am Up
Trade Rating: +13
No. Fronts are all standard. Rears are black Lexus. But been on since I got it.
2005 1.4 16v Sport
BSI software bug by the sounds of it.
Tolkienfan001
PostPosted: Mon May 13, 2013 9:19 am Up
Trade Rating: +13
Ok so this is where my experience is at its lowest. Is there anything I can do to sort it or do I need a visit to pug?
2005 1.4 16v Sport
PostPosted: Mon May 13, 2013 9:21 am Up
Just reboot it & see how it goes.
Did you get your gearbox earth sorted?
Barking
PostPosted: Mon May 13, 2013 9:22 am Up
Is she called Christine at all? Wink
I got a dig bick.
You that read wrong.
You read that wrong too.
Tolkienfan001
PostPosted: Mon May 13, 2013 9:25 am Up
Trade Rating: +13
Yea I have a brand new earth strap.
I just don't get it the car runs so well starts first time. It's just this random beeping the oil light the other day and now the radio. I am at a complete loss!
2005 1.4 16v Sport
Check the alternator earth starp connection on the unit itself too.
And reset BSI anyway as said above.
Tolkienfan001
PostPosted: Mon May 13, 2013 9:28 am Up
Trade Rating: +13
Ok thank you guys I really appreciate you sharing your knowledge. I will reboot the BSI. And will look into the alternator earth.
I will message back if it continues after these jobs.
2005 1.4 16v Sport
Tolkienfan001
PostPosted: Mon May 13, 2013 10:45 am Up
Trade Rating: +13
Guys,
I have had a look at my Haynes manual, but there is no mention of an earth strap on the alternator. I believe my alternator is located on the left hand side of the engine under the power steering. I can see one plug going into the alternator but where would the earth be?
2005 1.4 16v Sport
PostPosted: Mon May 13, 2013 10:58 am Up
Guys,
The alternator is bolted to the engine block which is in turn attached to the gearbox.
The whole lot is earthed as its all attached together.
Tolkienfan001
PostPosted: Mon May 13, 2013 11:11 am Up
Trade Rating: +13
Guys,
So the earth on the gearbox that I have changed covers this then. I will try the reboot.
2005 1.4 16v Sport
PostPosted: Mon May 13, 2013 11:12 am Up
Guys,
Yes.
Page 1 of 6
