Forums › The Car › 206 Problems › Rear axle not looking right |
Posted: Wed Aug 13, 2014 4:48 pm |
Hi all
I hope you can help. I have a 206cc and replaced the rear axle as the drivers side wheel was leaning in. I was told it had basically started to collapse.
I purchased a refurbished one from IM Axles at a cost of £240 (in delivery).
Now from what I have been told the axle is held in place by 4 bolts.
But when I look at the back of the car the drivers wheel is sitting about an 1/2 inch further in and the passenger side is 1/2 inch out. At first though it was the wheels so changed them, but it is still sitting the same.
There is no banging or clanging when you drive, but could the axle be refurbished incorrectly?
Will try to upload a pic asap
Posted: Thu Aug 14, 2014 1:43 am |
Are the wheel dimensions the same?
Posted: Thu Aug 14, 2014 2:14 am |
Hi there
All 4 types are the same size. The new wheels on the car are Peugeot 15" scirocco wheels, before that I had a set of 15" TSW wheels
