Posted: Fri May 30, 2014 10:04 am |
Guys im about to buy 180 mirror from scrap yard ,
right now how could i test it so that i can know the folding motor still working
which wire i need to tap ?
thank you
Posted: Fri May 30, 2014 10:18 am |
there should be a grey and purple if memory serves me correct.
Posted: Fri May 30, 2014 10:33 am |
iainlovatt wrote: |
there should be a grey and purple if memory serves me correct. |
okayh, i will try, it doesnt matter which polarity?
Posted: Fri May 30, 2014 10:38 am |
yes one folds out and one folds in
Posted: Fri May 30, 2014 10:42 am |
i found your old post
ere is a quick picture which i will improve at some point when i have time.
So you need to decide whether you want to cut into the mirrors and/or the loom in your car or just make a new loom like the i did. (you could also get the connect blocks and create a loom between them..)
Basically there are 9 wires on a passenger mirror and 7 wires on a drivers side, unless you have fake mirrors which are becoming more popular now (ie GTi ones with the 180 caps on!! So be careful!!
Right on the passenger one there are a total of 9 wires which are as follows:
>Red movement
>Blue movement
>Green movement
>Brown heated
>brown heated
>black temp
>black temp
>Grey Fold in
>Darker Grey Fold out
Drivers side 7 wires [b]
>Red movement
>Blue movement
>Green movement
>Brown heated
>brown heated
>Grey Fold in
should it be grey and darkey grey? or gray with purple, sorry not really into wiring
Posted: Fri May 30, 2014 11:05 am |
There are 2 wire's for the folding function, all you do to activate the function is apply 12 volts down those 2 wires.
When you swop the polarity around on those 2 wires the function will reverse.
There is a PCB inside the mirror that controls folding & when to turn off the power to the folding motor at both the end stop folding positions.
Posted: Fri May 30, 2014 11:22 am |
MrBSI wrote: |
There is a PCB inside the mirror that controls folding & when to turn off the power to the folding motor at both the end stop folding positions. |
thx mate
