Online Now [28]:
Visitors: 27
Today: 17305
Total: 116669164
Forums › The Car › 206 Problems › Rubber Pipe Loose Hanging down 2.0L HDI
Drabod
PostPosted: Fri May 30, 2014 3:27 pm Up
Hi Guys Just Noticed a pipe hanging down from underneath the front end of my Peugeot 206 2.0 HDI. I'm unsure whether the patch of fluid underneath is from it or not.
Wondered whether anyone would be able to tell me what is for/what is connected to.
Cheers Rob
206Tom
PostPosted: Fri May 30, 2014 3:32 pm Up
Its the drain from the bottom of the fuel filter. there's a screw plug underneath, if its leaking maybe its come loose, just tighten it up again. Smile
Drabod
PostPosted: Fri May 30, 2014 3:34 pm Up
So it should just hang down like that? Thankyou for the quick response
Cheers Rob
206Tom
PostPosted: Fri May 30, 2014 3:47 pm Up
Yeah it just hangs there, that's normal.
Drabod
PostPosted: Fri May 30, 2014 3:51 pm Up
Thanks for the help :), As you can probably tell i have just purchased this car so was worrying Smile
Thanks alot Rob
206Tom
PostPosted: Fri May 30, 2014 4:05 pm Up
No worries, I've only just bought the 206 as well, had the same 2.0 HDi in many 306s before though, know them pretty well now haha!
