Latest: Kifi69
Overall: 17183
Online Now [646]:
Visitors: 645
Today: 57872
Total: 144517682
Forums › The Car › 206 Problems › Electrical use affecting revs
Antknee
PostPosted: Fri Jun 20, 2014 2:03 pm Up
this might or might not be related to my other thread Injector open circuit
When the engine is running the revs change with the use of electrical features, ie windows, heated screen, lights, radio.
Thought it might have been the battery but tested and its holding its charge at 12.6, when runnig it goes up to 14.something but drops down to 12.something or 13.something with the use of the above
Not really sure where to look now, checked all the earth straps and everything seems to be earthed fine
Car is now a 1.4 petrol (TU3JP) if that helps, thanks!
PostPosted: Fri Jun 20, 2014 2:14 pm Up
It's normal for the voltage to drop when you put load onto the battery, but dropping that much could be a sign of the alternator on the way out.
It would be worth going to a garage and asking them to check the alternator with the correct equipment.
