Forums › The Car › 206 Talk › Does any 206 use a clutch switch as standard? |
Posted: Sun Jun 22, 2014 4:23 pm |
Looking at wiring up the full throttle gear change on my 206 and it needs a clutch switch adding. Trying to find one on euro car parts. Does anybody know if any 206 has one as standard? It's not the same as a brake light switch is it? Looking at the way it mounts to the pedal box it might fit....
Posted: Mon Jun 23, 2014 3:28 am |
I think the models with cruise control would have a clutch switch. Don't know if there was any specific model that it came as standard on though.
Not much help, but might be able to find it on servicebox somewhere. It's not under Driving assistance>Cruise control though.
Posted: Mon Jun 23, 2014 3:35 am |
Trade Rating: +59
My old 1.6 HDi had one as standard, drop me a PM if you need the VIN.
| '98 Nile Blue 306 GTi 6
'04 Obsidian Black 206 GTi 138 | |
Posted: Mon Jun 23, 2014 6:33 am |
Excellent. Found it straight away on Service Box. Was with the clutch master cylinder section. Switch and clip are £17.52. Lovely.
