Forums › The Car › 206 Talk › Final drive ratios |
Posted: Sun Jul 06, 2014 11:39 am |
Need advice about final drives,, want to lower the gearing in my 206 180 and wondered what crown wheels and pinions I could use from other cars
Posted: Sun Jul 06, 2014 12:01 pm |
Some 307 xsi models come with a 4.79 I think...might want to check to see if I'm right with that ratio.
Posted: Sun Jul 06, 2014 12:05 pm |
Just look on servicebox. You will find it out from there or contact a specialist
| Team Impossible Possible
