Forums › The Car › 206 Talk › Camshaft and Crankshaft Oil seal replacement neccessary? |
Posted: Mon Jul 07, 2014 9:58 pm |
Hi Gents,
I'm going to be replacing the cambelt and waterpump shortly so I'm just sourcing all my bits and bobs. I was wondering whats the forum opinion on replacing non-leaking oil seals (cams and crank). Should I do this as good practice? My gut says yes but im thinking about the task of getting those cam gears off It sucks!! Anyway I'd be interested to know how many of you guys have done those and under what circumstances.
Thanks in advance gents.
| 206 gti 138 2003 stock stock stock  | |
Posted: Tue Jul 08, 2014 12:23 am |
They rarely give any trouble so I wouldn't bother.
Posted: Tue Jul 08, 2014 12:49 am |
If its not leaking then I wouldnt worry
| Team Impossible Possible
Posted: Wed Jul 09, 2014 1:25 am |
Ok, Thanks for the recommendation gents one less thing to replace.
Cheers
