Latest: Puggingalong
Overall: 17129
Online Now [219]:
Visitors: 218
Today: 5498
Total: 101298485
Forums › The Car › 206 Problems › ESP fault
ESP fault
Pezxx
PostPosted: Tue Jul 22, 2014 5:20 am Up
After plugging in pp it came up with c1310 yaw sensor signal fault showing 17v it should be between 9 and 16 it also came up with the esp electro valve supply relay status fault. Would this be causing the 17v if so where is the electro valve relay situated, any help would be appreciated!
