Latest: Beduff1977
Overall: 17134
Online Now [637]:
Visitors: 636
Today: 28198
Total: 108844223
Forums › The Car › 206 Problems › Tailgate replacement
Mattsard
PostPosted: Sat Oct 04, 2014 10:14 am Up
Hi, a friend has bought her daughter a 2005 206, 1.1 sport 3door as her first car. The rear tailgate is not in great condition. Would a tailgate from a 5 door fit? And is it easy enough to do? I'm no master mechanic but can find my way round a car, my main query is about the wiring is it on a plug or am I in for a load of soldering?
Also the 12v needs replacing, is access via the gear stick gator and shoving my hand in the gap?
Thanks very much
PostPosted: Sat Oct 04, 2014 11:47 am Up
The tailgate from a 5 door will fit. Just 4 bolts off the top of my head and from what I remember the loom is easily changed. It just plugs in near the N/S/R light
The 12v socket is easier to get to if you remove the trim behind/around the handbrake. The other option is to pop out the window switch and struggle through the hole.
Mattsard
PostPosted: Sat Oct 04, 2014 12:10 pm Up
Thanks macca
Mattsard
PostPosted: Fri Oct 10, 2014 2:29 pm Up
Macca, took the electric window switches out (the whole thing inc the little panel they are fitted into) then prise the metal bit of 12v socket out the orange plastic surround. then wiggle the orange plastic bit out.
