Latest: tbafonso
Overall: 17130
Online Now [256]:
Visitors: 255
Today: 48475
Total: 103409756
Forums › The Car › 206 Problems › seat belt lights of even when no one puts them on
cat41
PostPosted: Wed Dec 17, 2014 1:40 am Up
Hi, my GT has has another 8 hours work spent on it, all good fun.
One problem was both seat belt and air bag lights stayed on, just over 3 hours of work to find some twit hadn't crimped a cable, any way this fixed the problems straight away, but i,m not sure if my car should tell me that people should put their belts on.
Mine has next to the air bag lights a light that shows 2 people and 2 side bag signs, these are orange, been told the seat belt light is red.
Because my gt is slightly older does this have them?
PostPosted: Wed Dec 17, 2014 3:42 am Up
The orange sign is for passenger airbag. Drive your car above 10mph without a seatbelt on, the light should flash and chime to tell you put a seatbelt on.
PostPosted: Wed Dec 17, 2014 3:43 am Up
White plug under drivers seat connects to drivers seatbelt buckle IF your 206 has the red seatbelt warning light fitted.
cat41
PostPosted: Wed Dec 17, 2014 9:59 am Up
White plug under my seat is just hanging, i tried to see if there's a red light but can,t see it, i,ve tried 80 with no seat belt but still ho light, i guess mine didn't have seat belt warning lights.
PostPosted: Wed Dec 17, 2014 10:20 am Up
You would need to fit the drivers buckle with sensor & fit a bulb in the cluster if you want it to work.
Short the white plug out, see if the red warning light comes on.
PostPosted: Wed Dec 17, 2014 1:17 pm Up
What He Said
cat41
PostPosted: Wed Dec 17, 2014 2:16 pm Up
This car has been hard work, only cost 700 quid but it was a gamble with coolant disapairing, rad fan not working, and loads of fiddly faults.
It had pressure tests, checks for gases in coolant but the disappearing coolant was the bloody clip on the bottom of the expansion tank, it would leak 1 minute and not the next but luckly i caught it last week.
The fan not working on the rad turned out to be a faulty relay.
It has all the air bag light on all the time, as i,m small i pulled the front air bag out and we had to check the wiring, i did the front air bag my macanic did the seats, some twit had cut the cables under the seat because the car had a fault before i bought it, it was the dam wiring not crimped right, doing those wires fixed the lot.
The handbrake wouldn't work but funny this, 4 clicks the beaks dont work, 3 clicks they do.
1 big fault i didn't want left rear wheel is on the lob.
The front right shock is leaking badly so its news ones soon,
