Online Now [52]:
Visitors: 51
Today: 76974
Total: 105970930
Forums › The Car › 206 Problems › Drivers Seat
Drivers Seat
ECB93
PostPosted: Fri Jan 30, 2015 12:36 pm Up
Hi all,
Sorry if this has been mentioned before, ran a search and nothing came up. So I'm after some advice -
The drivers side seat on my Gti doesn't click into place when you adjust the angle of the back, i.e. you can have it right back or folded forward. Don't know if anyone else has had the same trouble and there's a solution?
Also would it be possible to swap the drivers and the passagers seat around as the passengers is ok, thus solving the problem (well for the driver anyway)
Take it this is down to how the seat belt plug is mounted.
Anyway thanks in advance!
PostPosted: Fri Jan 30, 2015 3:33 pm Up
Even if you swapped them it is almost certainly MOT failure.
